1/4"-20 UNC to 1/8" NPT Adapter?
PatrickPresti
Islip, NY
Hi Guys,
Do you know if there is such a thing as a 1/4"-20 UNC to 1/8" NPT Adapter?
Right now my muffler drain fitting is a 1/4" - 20 bolt with a o-ring on it. I want to get rid of the screw and replace it with a ball valve.
Thanks,
Pat
PatrickPresti
Islip, NY
Hi Guys,
Thanks,
Pat
I actually think I found what I need... Thoughts?
djmarchand
Atlas Pompano 23 outboard
That should work. Since it will connect to a ball valve and get some twisting force on it, I would leave out the o-ring, put some Permatex or similar where the o-ring goes and tighten it down real good.
Genius
Hi Guys,
Thanks,
Pat
Check out discounthydraulics.com it’s my go to for adapters.
captjohn
Seaford, NY
Henriques
Not sure I want a fitting, and a valve, hanging off threads into fiberglass
Agree, too much hanging on such a small thread (1/4") and the fitting is brass and will dezincify and break with vibration. Bad move.
captjohn
Seaford, NY
Henriques
I have done it in the past with no issues. I guess I can substitute the ball valve with a stop cock...
I would just hate for you to have it snap off and fill the bilge on you. The longer it is the more it becomes a lever. A little vibration can end up being multiplied.
Top
