2001 28 BHM (Seaworthy) Tuna/Charter/fishing
Discussion in 'Classifieds for Downeast Boats' started by Raider Ronnie, Jun 5, 2019.
  1. Raider Ronnie
    Raider Ronnie Captain
    2,264
    782
    BHM 28
    Yanmar 6LP-STE 315 hp. (3740 hrs as of 6/5/19) w/waterlift muffler
    ZF 63A transmission w/ troll valve
    210 gallons of fuel in (2) 105 gallon tanks
    Dual Racor fuel filter assembly w/ selector valve
    Built in oil change electric pump
    3 steering stations (wheelhouse, stern, tower)
    Buss heater in wheelhouse off engine coolant
    Marine head w/ electric flush & holding tank
    Microwave oven
    (3) 8D batteries (2 new this year, other 3 years old)
    Electradyne hauler w/gin pole & block
    Shore power w/ outlets v-berth & wheelhouse & onboard battery charger
    Custom port side seating that folds down
    Engine box seating w/ tackle & general storage
    Helm seat on bulkhead swivel mount (removable)
    Stb side swing up door
    Custom bi-fold winterback doors
    Cockpit/fishing
    70 gallon below deck livewell w/high volume pump, 6 overflows (2 stern, 2 each side) & pumpout
    2 below deck 48x24x16 insulated fish holds with anchor hatches
    Rule 17a high volume washdown w/ 1 1/2 hose (16 ft new this year)
    Transom walk thru door
    Custom transom (hidden/fold down) helm controls
    Tower w/helm controls. (Easily removed for transporting)
    Custom port side ladder to access tower/roof
    Rocket launcher for 8 rods (roof mounted)
    Rocket launcher for 6 rods (tower)
    Port side rod holders for 6 rods
    Rod holders for 6 rods (winterback door)
    V-berth has 3 built in rod holders (storing 130s on butts)
    10 LD Marine swivel rod holders (8 0 degree cockpit, 2 15 degree stb side at helm
    6 Lee rod holders (cockpit) (bass rods trolling, chunking.... ect)
    Roof mounted Lee outriggers
    Lee Center rigger
    Tower mounted LD heavy duty outriggers (pulling spreader bars)
    Electronics
    (2) Simrad NSS12 displays
    4 G broadband radar
    BSM-2 chirp sounder module
    Airmar B275 1K chirp transducer
    Pair (stainless with faring blocks) side/down scan transducers
    Simrad AP-24 auto pilot (interfaced with NSS displays)
    Raymarine E80 display
    M260 1K shoot thru transducer
    DSM 300 sounder module (have spare module also)
    Garmin 2010c chart plotter
    Garmin 2006 chart plotter (tower)
    Standard horizon vhf w/hailer, Horn, fog signals
    2nd vhf will be included, either unit with scrambler or other unit with expanded channels
    Safety gear
    Revere 4 person canister (roof tower base mounted) liferaft (new in 2016)
    Epirb
    Life jackets
    Throw ring
    3 fire extinguishers
    Commercial 50 mile offshore flare kit
    Vessel has a CG commercial dockside exam sticker good till 2021
    Boat got a new (raised) deck 5 years ago, transom - dash bulkhead
    Stringers are full height (2 inch Nidacore) and 2x2 fiberglass angle that the deck is glued & fastened to.
    All wood was removed and Coosa deck installed with vinylester resin used with fiberglass Matt & 1708 cloth used top & bottom sides of deck.
    This winter boat got a major rehab/facelift
    Hull Awlgrip 545 primer & Awlcraft paint (gray)
    Spray rails, qtr rails white, boot stripe red, both 545 primer & Awrcraft paint
    V-Berth, wheelhouse, cockpit & deck all new gelcoat (White/gray non skid)
    Most everything removed for the rehab (no sand & mask job)
    New custom stainless stern corner trim/protectors , fabricated-polished to mirror finish & installed
    All bilge , livewell, macerator, pump out pumps replaced this winter
    I am the 2nd owner
    Bought this boat in June 2008 with 144 hrs
    Motor / boat has never gone more than 125 hrs between oil changes & fuel filters
    (most changes @ 100 hrs) in the time I’ve owned it. Prior to that it got more coats of wax that hrs put on it it’s 1st 7 years
    All recommended maintenance done according & above recommended schedule (timing belt, tensioner, idler pulley, valve adjustments, alternator belts replaced, transmission oil replaced annually ,engine & boat zincs, turbo washes)
    Intercooler serviced & cleaned annually.
    Heat exchanger been removed & cleaned very 3 years ( though each time not necessary upon inspection after removal.
    2018 replaced 6 new fuel injectors, new OEM raw water pump assembly
    Boat cruises 15-16 kts depending on load & conditions (17-18kts with a light load) tops out @ 22-23 kts
    15-16 kt cruise @ 300-3200 RPMs it sips fuel !!!
    Boat has been stored each year since 2009 inside a giant Shelter November- March at my house (out of the winter elements)
    Asking $86,000
    Ronnie
    508 326-9287 or email
    ronnie@bostonharborcharters.com
  2. Raider Ronnie
    2,264
    782
    BHM 28
    Pictures
    Rockasauras, Toolate and Plastered like this.
  3. Raider Ronnie
    2,264
    782
    BHM 28
    More pictures
  4. Raider Ronnie
    2,264
    782
    BHM 28
    A few more pictures, with tower on (haven’t put tower on in a few years)
  5. fishpicker
    fishpicker Member
    Aug 1, 2012
    11
    Wow.
  6. Raider Ronnie
    2,264
    782
    BHM 28
    Wow good or bad ?
    Did I mention this is a very fishy boat and seen a lot of big fish !
  7. 2na
    2na Member
    Jan 14, 2013
    57
    6
    Nice boat!
    2na,
  8. fishpicker
    fishpicker Member
    Aug 1, 2012
    11
    Wow like real good!
    Wow like "....I wish I had the $$ for it..."
    Good luck with the sale
    The Porgyman likes this.
  9. Beamie
    Beamie Senior Member
    Jun 3, 2012
    240
    72
    For the amount of customization, electronics and recent refresh you would be hard pressed to find a more decked out 28 footer
    What a Pissa boat. Glws Ronnie. Maybe see ya mid sept. Away on the ship til then. Hope the boys doing well at mma. Jon
  10. plowin
    plowin Captain
    Dec 14, 2011
    1,235
    850
    Firefighter/Half Assed Fisherman
    Newbury
    33' flowers
    This is a no brainer boat for someone thats really looking. The price is a bargain compared to actual cost!
    tuna_fan and Blitzen like this.
  11. Renegade24
    Renegade24 Member
    Nov 27, 2016
    84
    16
    Long Island
    24 ROS & 24 Privateer Renengade
    Aluminum or plastic fuel tanks I know the earlier seaworthys had problems with the plastic fuel tanks
  12. Toolate
    Toolate Captain
    5,528
    1,567
    Building contractor
    Jesus what a ride! Amazingly clean and well thought out oh and CLEAN! Nice work and good luck.
  13. El Mar
    El Mar Captain
    6,730
    2,445
    I remember when Ronnie took a Skil Saw to the Stbd side.
    Really is the best laid out 28 available.
  14. Toolate
    Toolate Captain
    5,528
    1,567
    Building contractor
    Really puts all these filthy boats we see for high numbers to shame....
  15. Raider Ronnie
    2,264
    782
    BHM 28
    Thanks for the kind words gentlemen.
    No question, this is probably the most well laid out & equipped 28 BHM around
    I’ve spent the last 10 years making it that way and have spent a ton of $ doing so.
    The boat has caught a TON of fish in and around Boston Harbor, mostly big striped bass, blue fish & flounder, my son & I have put a handful of tuna on the deck and 100s of lbs of sea scallops were shucked buy myself and scuba divers I would take out in Boston Harbor.
    Someone is going to get a great boat !
    Keelboater likes this.
  16. Force Multiplier
    Force Multiplier Member
    Sep 24, 2018
    15
    Nice looking boat. So the tower is easily removable? Do you have any idea how much the tower weighs.
  17. Raider Ronnie
    2,264
    782
    BHM 28
    About 100 lbs.
    The boat handles it fine and has little effect rolling
    Force Multiplier likes this.
