36 Harris refit in ct
Discussion in 'Downeast Projects and Boat Building' started by Blueff62, Mar 3, 2019.
  1. Blueff62
    Blueff62 Member
    Sep 22, 2012
    10
    6
    Hi , I m doing a repower on this boat I picked up about a year ago. Had an old 3208 natural with a
    1 1/2" shaft I'm putting a QSB 480 Cummins in . Need a bigger shaft 2"
    Anyone have thoughts or tooling to bore out the shaft log ? I have some ideas but just looking for some others that may have done this before . I have a new shaft log Fiberglass tube 3 1/4 od 2 3/4 id. Any thoughts or suggestions appreciated
    Islandlure, Keelboater and El Mar like this.
  2. Genius
    2,095
    917
    sawzall and a hole saw nested in another hole saw? The inner hole saw would have the same OD as the ID of your present log. The outer hole saw would be 3-1/4. I've never done it, but that's how I would attack it. The new shaft may not be in the same location as the old one depending on how the new engine and gear fit. So....it really doesn't matter how accurate the removal is done.
  3. El Mar
    El Mar Captain
    6,605
    2,340
    I wondered how this project was going the other day.
    Did you rebuild the interior?
  4. tashmoo2
    tashmoo2 Senior Member
    Sep 2, 2011
    375
    56
    Shennecossett Yacht Club Groton CT
    HI Blueff62
    Is this the hull from Glen in Newtown? Glen said it was going to a new home in Norwalk. I bought bare hull with sport fish top and loose cockpit from Ron Tarr in 1977 and finished hull in CT.
    I have a lot of data on the boat. Ron Tarr installed tube and filled keel void with fiberglass resin and sawdust. Have you started to take out old tube? It might be easier to grind/cut it out from inside. The max diameter prop you can swing is around 24 " with current keel depth. What prop and gear reduction will you use?
    I am in Ridgefield and happy to help
    Best regards,
    Ed
  5. Drifter
    Drifter Member
    Dec 31, 2017
    19
    Just did that with mine. Went from 11/2 to 13/4. Had plenty of room to bore out stuffing box and put different cutlas in stern bearing. Paul at new england machine in deep river did it for me
  6. tashmoo2
    Sep 2, 2011
    375
    56
    Drifter: Do you have a Ron Tar Harris hull? Is your stern bearing in a strut or the keel?
    I have a 1 3/4" shaft in my boat. I did not think the cast bronze strut was large enough for a 2 " cutlass bearing or the tube for a 2" shaft would inside the keel. The keel was not filled when I got my boat.
    Does your hull have a full keel all the way aft?
  7. Drifter
    Drifter Member
    Dec 31, 2017
    19
    No I have a mdi wet keel with a stearn bearing at end of keel, sorry to mislead you. My father had a 36 Harris that he sold to Rick with priority charters in R I. I know he put a cummins c in it and may have had to upgrade his shaft. Might be worth a call to him
  8. Drifter
    Drifter Member
    Dec 31, 2017
    19
    And yes it was from Ron tarr
  9. tashmoo2
    Sep 2, 2011
    375
    56
    Hi Drifter,
    I know your Dad. Howard if boat was the Nancy B with the 6-71N. Good fisherman. He may not know me very well but he knows my boat. There were only 3 or 4 of us in the area with 35 Harris's. Nancy B, Dottie D, Ho0ked up and Tashmoo II. I thought all the 35 Harris hulls had a skeg. Did you or Ron Tarr install the stern bearing?
  10. Drifter
    Drifter Member
    Dec 31, 2017
    19
    Yes he had the Nancy b . I believe the shaft was installed by Ron tarr. It did have a skeg, my boat the mdi has a stern bearing
  11. Blueff62
    Blueff62 Member
    Sep 22, 2012
    10
    6
    Hi , yes got this boat from glen in Newtown . I'd certainly be interested in your info . You probably know
    not yet
  12. tashmoo2
    Sep 2, 2011
    375
    56
    you can call 914 316 6418. Leave message if I do not answer
  13. johnnywhale
    johnnywhale Member
    Jan 4, 2018
    24
    11
    Is this a Harris?
    Log In or Sign Up to View
  14. tashmoo2
    Sep 2, 2011
    375
    56
    I do not use Facebook
