ATF for ZF transmission which one?
casey87
New Member
Likely overthinking but the list of ATF ZF provides seems to be near useless as most seem to be euro products, the only that seems attainable locally is Delvac ATF 1 which is full synthetic and it seems like some recommendations online are to avoid full synthetic?
What are you guys using ? I have a ZF-80.
Thank you!
JimRP31
tiverton RI
Willis Beal/RP 31
There should be a plate on the side of your transmission which will indicate the type, weight & quantity.
A have a ZF63A bolted behind the Cummins 370.
The gear calls for ATF III
I used Delvac ATF synthehtic, but now I've switched to 15-40 oil, same iol as Cummins engine.
Makes changing so much easier using oil vs oil and ATF on a change in both engine and gear
Top
