Bow thruster on a Sisu 22
Discussion in '"Pocket" Downeast Boats (14-24ft)' started by RobBaker, Feb 8, 2020.
  1. sockeye
    sockeye Senior Member
    Nov 18, 2011
    125
    64
    BHM 31
    What model are you installing?
  2. BillD
    BillD Captain
    6,237
    1,847
    Business owner
    not that far yet
    I'll have New England Bow Thruster do the install.
    I think they use Lewar
  3. Kenneth
    Kenneth Senior Member
    Jun 19, 2014
    144
    42
    Glassing the bottom side of the tube is the real PIA part.
    BillD likes this.
  4. RobBaker
    RobBaker Senior Member
    Sep 25, 2018
    108
    56
    Eastern Sisu 22
    You did a nice job mine will have a little more room underneath but understand the challenges. Drilled the pilot holes today and the unit arrived today need to measure the tube and get a hole saw next.
  5. Kenneth
    Jun 19, 2014
    144
    42
    I think a hole saw will create an oblong or egg shaped hole due to the curve of the bow. I made a jig out of threaded rod to mark mine, then cut it out with a jig saw, i'm sure there a other ways to do it.
    Genius likes this.
  6. Toolate
    Toolate Captain
    5,967
    1,866
    Building contractor
    Mine was so close to the point of the hull on the bottom that I put a piece of foam core in there and glassed it all together. Was not able to wrap tube entirely because the clearance was so low but it was totally encapsulated and then I think I laid up like 4 overlapping layers of 1708 tabs all around it plus csm Inside and out then faired it with hull and deck with glass fibers from csm mixed in. If there is core remove it so tube is glassed to hull skin in and out. Fun project once you are past the interior grinding stage.
  7. Shor2832
    Shor2832 Senior Member
    Dec 18, 2013
    363
    261
    Portsmouth, RI
    JC31
    Drawing the proper diameter circle on a piece of paper, with center marked, then transferrng to hull makes it easy too.
    Toolate likes this.
  8. RobBaker
    Sep 25, 2018
    108
    56
    Eastern Sisu 22
    My plan is to replace the pilot drill bit in the hole saw with a steel rod. The rod being long enough to go thru the hull on both sides. Go thru 90% on one side then pull it out and get the other side. If this works it should do away with the oblong shape hole.
  9. Genius
    3,122
    1,664
    won't work. the hole saw isn't deep enough.
  10. RickC137
    RickC137 Senior Member
    Dec 16, 2018
    107
    86
    Eastern Sisu 22
    Rob, post a pic of the plug. Want to see how thick the hull is there.
  11. RobBaker
    Sep 25, 2018
    108
    56
    Eastern Sisu 22
    Genius good post, got me thinking. The standard hole saw is 1 3/4 deep for going thru a 2*4. They make a deeper one FREUD DHS4500 High Performance Hole Saw which is 2 3/8 inch deep which should help me but not resolve the issue you pointed out. Perhaps I can do most of the cut from the outside and finish up on the inside. Time will tell. My tube is small a little over 4.5 inches so that should also help. I'll have my jig saw handy just in case.
  12. Roberto
    Roberto Member
    Aug 23, 2019
    20
    14
    22' Sisu
    Rob, did you go with the Lewmar 110TT thruster?
  13. RobBaker
    Sep 25, 2018
    108
    56
    Eastern Sisu 22
    Yes I did. The motor was almost 2" shorter then the Side-Power.
  14. eglicomet
    eglicomet Member
    Mar 31, 2014
    66
    28
    Motorcycle collection curator
    Long Island, NY
    Hey Kenneth, can you post photos? I'm doing a minor refit on my old Dyer project and a thruster is on the dream list of upgrades.
  15. Brent
    Brent Member
    Sep 22, 2018
    27
    16
    Sternman
    Pemaquid Beach
    My 22 sisu didn't have enough bow in water for one of them.Id practice docking if I was you
    Flying Finn likes this.
  16. RobBaker
    Sep 25, 2018
    108
    56
    Eastern Sisu 22
    Brent I’ve studied this enough to determine that a thruster will work on my boat. Stay tuned to this thread should have a 4.5 inch hole within the next two weeks weather permitting it’s cold out there.
  17. Kenneth
    Jun 19, 2014
    144
    42
    I've not got past the tube install as of yet.
