Check those exhaust tubes
Discussion in 'Downeast Engine Room' started by backman, Jan 16, 2020 at 6:11 AM.
  1. backman
    backman Captain
    Jul 9, 2012
    867
    288
    Falmouth, Ma
    Northern Bay 36
    As part of winter maintenance we proactively replaced my 10 year old/5000 hour black exhaust tube with a new blue silicon one. I had noticed cracks on the outside the past season, look what the inside looked like!
    it’s a QSM 11 engine and at idle after a couple hour run the top of the tube was about 220 degrees with a heat gun...
  2. ARC
    ARC Senior Member
    Sep 30, 2017
    347
    258
    Hydraulic service
    great South Bay
    31’ eastern Casco Bay
    Why was the hose that hot? I can always touch mine without pain.
    ARC,
  3. Genius
    3,035
    1,577
    Bad shower head design. TA talks about it on seaboard marine's website. One size doesn't fit all.
  4. WoundUpMarine
    WoundUpMarine Captain
    3,815
    1,893
    Merchant Mariner - Engine
    Boothbay, Maine
    26 Duffy, 14 Holland
    I looks like that mixer is almost horizontal going aft. When the engine is idling, less water is being pumped. Heat goes up and water goes to the bottom of the mixer. Maybe a new designed mixer isn't a bad idea.
    Genius likes this.
  5. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    I found this interesting on my Scania, the size of the holes. This works well. engine exhaust mixer.jpg
    Genius likes this.
  6. Genius
    3,035
    1,577
    besides the hose issues. This design is a wet jacket design which is not best practice. No dry riser doesn't help either. No pitch. ugh. Sorry, but it will save you problems in the future if you correct these items.
  7. WoundUpMarine
    3,815
    1,893
    Boothbay, Maine
    John, did you ask anyone about the reasoning behind having smaller holes at the top? I would have thought it would have been the other way around, cause a restriction low to force water towards the top of the mixer.
    Toolate and Genius like this.
  8. Genius
    3,035
    1,577
    yeah, seems upside down?
  9. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    This is the mixer that was supplied with the engine. Every install is unique and needs proper attention. Here is the arrangement we went with, spill over point is 24 inches above the waterline and all water is on the down stream side of the exhaust. Riser by Tim Toppins and has since been hardcoated. Exhaust 1.jpg
  10. Genius
    3,035
    1,577
    why is the drain at the top?
  11. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    I thought so too but it actually makes more pressure at the top to give a better spray pattern. didn't believe it until I saw a video of it in action. There is a tremendous amount of water flowing through the system.
  12. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    That is not a drain.
  13. Genius
    3,035
    1,577
    what is it?
  14. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    Back pressure test port.
  15. Genius
    3,035
    1,577
    Shouldn't that be on the dry side?
  16. Genius
    3,035
    1,577
    interesting!
  17. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    You got me there, maybe I am wrong. Always had a plug in the elbow to test back pressure but your logic sounds right.
  18. Genius
    3,035
    1,577
    sometimes a tell tale is run to make sure raw water is flowing. Run over the side into a thru hull fitting above the water line. Maybe it is a port for that?
  19. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    Well I am going to look into that a little further and see what the answer is. I am sure Tim could answer the question right quick. I will report back with an answer.
    Genius likes this.
  20. WoundUpMarine
    3,815
    1,893
    Boothbay, Maine
    It could be a bung welded on both sides, so still used for back pressure. I'm going to modify the mixer for my volvo to take a EGT probe that way. Or it could be a drain, hard tellin not knowin.
