Circle Hooks Shark
Discussion in 'Striper, Blues, Cod, Haddock, Hake, Sharks' started by ChrisXL64, May 26, 2015.
  1. restless
    restless Captain
    Jan 22, 2014
    1,753
    1,112
    Please let us know how they work.
  2. mako239
    mako239 Member
    Oct 10, 2012
    93
    95
    1987 28 BHM 210 Cummins
    circle hooks
    I have had pretty good luck with circles ive been using them for a while now ive a had 300 plus lb makos and a hammerhead pushing 400 on them .. My fav to use is a 16/0 and 18/0 Lp with offsets but ive also had luck with 18/0 and 20/0 non offset mustads... They have there plus and minuses but once there hooked they usually stay on and another plus is your not gut hooking small makos ...
  3. GLA
    GLA Senior Member
    Sep 11, 2012
    335
    134
    hooks
    this is the hook I have had not such good luck with
    it is a 18/0 lp
    somehow I think the leader gets tangled up in the teeth and pulls the hook out the front of the mouth and doesn't allow the hook to make it to the corner
    surprised others have had good luck with them. must be something with my setup, usually rig them on 400 mono
      File size:
      77.8 KB
      166
    GLA,
  4. El Mar
    El Mar Captain
    6,936
    2,626
    I bet the crimp is interfering with the hook set.
    We have had very good luck with the Mustads on single strand wire in 18/0 and 20/0.
  5. GLA
    GLA Senior Member
    Sep 11, 2012
    335
    134
    never tried one on wire, thought that is the reason for using them in the first place, so you don't need it.
    could be the reason, the crimp may be catching on something and interfering
    will have to try a short 3 ft piece this season
    I will say the mono gets more hits on most days when that rig is in the water. almost like they are leader shy
    GLA,
  6. El Mar
    El Mar Captain
    6,936
    2,626
    We run a small 5-6 foot leader to a swivel then the 400 mono.
    Works real well.
    How long is that crimp?
  7. mako239
    mako239 Member
    Oct 10, 2012
    93
    95
    I use the same as el mar 4 to 6 ft of single strand and 400 lb mono
  8. ChrisXL64
    ChrisXL64 Senior Member
    Apr 13, 2014
    212
    64
    You guys using wind ons with the 400? IE some kind of loop to loop with the main line?
    I've always used 49 strand to a big swivel on either end; and 2 foot of wire off of that to the hook. Considering switching to mono.
  9. mako239
    mako239 Member
    Oct 10, 2012
    93
    95
    I'm not using wind ons I would if I didn't have roller guides but I'm just replacing the 400 lb mono instead of cable
  10. El Mar
    El Mar Captain
    6,936
    2,626
    No wind on. Palomar to barrel swivel on 400 mono.
    Keep it simple.
  11. twister
    twister Captain
    Jan 10, 2013
    571
    85
    RI
    37 Mitchell cove
    I use wind ons, keeps it easy can wind the fish right in to the tip if just using mono if not 3' off. Easy as hell on the crew no need to worry about who goes for the leader if it's a busy day with lots of fish.
  12. Dave Wynn
    Dave Wynn Senior Member
    Jan 22, 2012
    142
    95
    Sales / Project Manager
    New York Harbor Sheephead Bay
    H&H 32 Desperado
    Im new to the circle hook idea. Im not a big fan of circle hooks at all !! Im old school. I was at trophy Tackle today to try to understand the set up. I like the mono idea alot. bought some 300lb leaders all riged up. I took a package od Eagle L2045M 20/0. figured Ill start there. Any thoughts open to any help.
  13. MBILL
    MBILL Senior Member
    Sep 2, 2011
    250
    50
    Retired
    35 Duffy&Duffy
    I finally got out yesterday and gave the Mustad 39960D some testing.
    I was looking for a Mako and started with my usual J hook rigs, not wanting to experiment on a Mako hookup if possible.
    Turned out that we were covered in Blue Sharks so eventually we went to the circle hook since most of my "J"s were gone.
    I have mixed reviews from my short test. I hooked the first one cleanly, started with a light drag, let him run and socked up the drag when the run was steady. The Blue was hooked in the corner of the mouth and I was able to get the hook back with some effort.
    After the first one, we had a lot of pickups where the Blue's dropped the bait. This did not happen with the J hooks.
    We hooked a couple more Blue's that swallowed the circle hook. The last one had our hook in it's belly and a rusting J hook in the corner of its mouth.
    I'll try again and see what happens. I'd guess that the circles will work ok if used properly on aggressive hookups but they're a problem if you're dealing with a lazy pickup.
    Digginit 38 likes this.
  14. LadyMaureen
    LadyMaureen Captain
    Apr 27, 2012
    824
    1,087
    South Shore Long Island
    Wesmac
    I did same yesterday. I used the 20/0 mustads all day. We fished on 15 pounds drag for strike. Caught 8 blue sharks and missed one bite. I don't prefer using these circles but my trip yesterday seemed to go just fine so I can't complain too much.
  15. mako239
    mako239 Member
    Oct 10, 2012
    93
    95
    Yes I hear ya on the lazy Bites it had me second guessing! I have lost some blue dogs due to lazy bites but knock on wood no makos yet.. Most of the big makos took the baits aggressive or showed themselves first and i caught them on pitch baits and I quickly put the boat in gear once they took the bait helping to secure the hook .. Here's a pic of pup hooked where its supposed to be..
    CaptLuke likes this.
  16. Rockasauras
    Rockasauras Captain
    Nov 9, 2013
    832
    293
    OCEAN CITY
    You hit the nail right on the head Bill. We have no leaders anymore, just politicians...and that goes all the way to the top
  17. Runaway36
    Runaway36 Member
    Aug 11, 2014
    29
    17
    I fished Saturday too, had mixed rigs out. I try and remove as many hooks as I can, we usually get back 90 % of the J-Hooks. I was only able to get 1 out of 6 of the circles back.
