DQX propellers? Worth it?
Discussion in 'Downeast Engine Room' started by CaptV, Jan 13, 2020.
  1. CaptV
    CaptV Member
    Feb 20, 2012
    54
    I need some advice please....I am thinking about buying a new propeller this off season and a friend told me to look at the DQX. The boat is a 35 five islands with a Cummins CTA 430 and currently has a 23 dia x 28 pit 4 blade LH. The propeller has been bastardized since I bought the boat 5 years ago as we have been constantly manipulating it to "make it work." I'm trying to get more out of the boat and engine and hoping that the new propeller will allow me to achieve that.
  2. Keelboater
    Keelboater Captain
    5,287
    3,200
    DQX style props are great for boats that have limited tip clearance like your 35 Five Islands which originated in the 35' Bruno mold.
    Reelman955 likes this.
  3. powderpro
    powderpro Captain
    Dec 3, 2011
    3,213
    2,471
    The Ocean
    O'Neil
    Yes, 23” diameter is small for that hp and size of boat, so I would recommend the larger blade surface of a DQX style prop. If you can jump up in diameter that will help too.
  4. CaptV
    CaptV Member
    Feb 20, 2012
    54
    Snapped some quick picks this am... any insight is always appreciated
  5. MikesMarine22
    MikesMarine22 Senior Member
    Oct 21, 2011
    443
    222
    Marine Mechanic
    Mass
    I have this if you have any interest. 1-1/4 shaft size
  6. powderpro
    powderpro Captain
    Dec 3, 2011
    3,213
    2,471
    The Ocean
    O'Neil
    A more accurate measurement for what prop will fit is to measure a little farther forward on the shaft, where the middle of the prop would be. But based off what I see, and assuming you have a little more clearance on top versus the bottom, a 24” diameter should work good. Increasing diameter 1” and going with a DQX should net you some positive speed results
  7. Gurryman
    Gurryman Captain
    Sep 6, 2012
    1,145
    670
    New Bedford MA
    Nauset 28, CuttyHunk 28 Molds
    What are the current performance numbers with the prop you have? Also what ratio is the gear?
    Keelboater likes this.
  8. mike@mpi
    [email protected] Senior Member
    Sep 1, 2013
    317
    129
    stevensville, md.
    26 JC
    Here's my take on the DQX. I repowered my 26 JC from the original 7.4 liter Ford to a 370 Cummins. Somewhere on here going back a few years I wrote about propeller issues. The old engine spun a Hy-Torq 17X14 with a 2:1 gear. Hy-Torq is now Michigan's DQX adding to the line of the old 3 blade Dyna Jet and 4 blade Dyna Quad. Since the boat came with what is now called the DQX but now would be larger and with less tip clearance with the increased torque with the Cummins I stayed with the Hy-Torq style and wound up with a DQX 18x21 behind a 1.5:1 Twin Disc which works out to about the same shaft RPM but raised the boat's top speed from 18 to 25 MPH. After 2 seasons and about 300 hours I saw severe pitting around the root where the blades attach to the hub. I thought cavitation from running behind a keel was the problem and had the pits welded up. This went on for 4 more years, 400 more hours, 2 more repairs and then the DQX threw a blade. I got Dave Gerr's propeller handbook and learned it was blade overloading that was causing the damage to the prop. The only fix is to get more blade area. Talked to Michigan and there are no 5 blade wheels that small but they recommended their DQ 486 which in 4 blades brings blade area up .74 to .86. It also in my small size prop weighs like 7 lbs more.. That's a lot of metal. 7 seasons and a 1000 hrs and the only thing I had to do to that 486 was have an inch of pitch taken out of it because it was grabbing so much more water that it was overloading the B. Now at 18x20 the boat gained 1 MPH and can turn up past rated RPM. If you can, look at both of them and see which is way beefier. I should also point out that in either wheel I didn't spring for Nibral.
    So no, I don't like the DQX.
    I don't know this is fact but I heard that the DQ486 is what Dave's original Tuna.com was running behind that big Mack E-9 American Marine.
    Kailua Kid likes this.
  9. CaptV
    CaptV Member
    Feb 20, 2012
    54
    The boat is upwards of 20000 pounds fully loaded with 6 customers, myself, ice, and fuel. Gear is a twin disc 507a 2:1. at 2100 where I cruise I'm around 14.5 kts. At 2625 its at 22kts. I feel like i Should be getting more out of it. I am also adding some zipwakes this offseason as well
    I'll head down in the am and get better pictures. I went quick at there was a massive puddle
  10. OLD BAY
    OLD BAY Captain
    Aug 25, 2012
    734
    318
    Annapolis, Md
    Wasque 32
    I have a 20x22 bronze DQ and a 20x21” nibral DQX in my Wasque with 1.5:1 gear. I have limited tip clearance with the 20” diameter and had rumbling at speed with the DQ.
    The DQX is smoother/quieter and a few tenths of a knot faster throughout the RPM range, including top end (I think 0.4 knots, but I reported it somewhere on this forum). I didn’t track this closely, but I have a floscan and I believe I get slightly better fuel burn for the same speed with the DQX. I used to get about 1.9nmpg at 20knts with the DQ and now I think I get about 2.0 nmpg. YMMV
  11. Keelboater
    Keelboater Captain
    5,287
    3,200
    [email protected] - I think you have a unique case with such a motor in that 26' JC. Your boat sounds like a good candidate for a keel modification. Bill D has a 370 Cummins with 1.5:1 gear on his 25' TJ and swings a 20" DQX prop, and if memory serves, he doesn't use the max HP. Sounds like you have it ironed out though. Nibral might have helped as well.
    Blitzen likes this.
  12. ripta13
    ripta13 Senior Member
    Feb 5, 2012
    215
    224
    1996 31 BHM
    I had good results going to a DQX in my 31 BHM.
  13. plowin
    plowin Captain
    Dec 14, 2011
    1,365
    1,002
    Firefighter/Half Assed Fisherman
    Newbury
    33' flowers
    Tell us what the results of the DQX on the BHM were. I never would have expected that with most BHMs, there is a ton of room for a large diameter wheel. What motor and reduction do you have?
  14. Blitzen
    Blitzen Captain
    4,035
    2,535
    Ex Merchant Mariner
    Had a DQX Nibral prop on my last two boats, smooth as silk and very efficient. The DQX design has a higher blade area than most 0.82 I believe and is great for boats that have limited prop aperture for the given power. With the increased blade area you can reduce diameter and pitch allowing the prop a little more room to work. Keep in mind most DE boats will do best with a prop that is a little over square. And shaft speed is also a consideration when choosing a good prop.
  15. ripta13
    Feb 5, 2012
    215
    224
    1996 31 BHM
    430cummins 2:1 twindisk. Pretty sure the old wheel was 4 blade Michigan nibral 26x28 it was tired so I was due for a new wheel. So Bossler & Sweezy on Long Island recommended 26x27 DQX I got my RPMs back and gained a little bit of speed at 2200 from where I was at. I was happy. This will be my 6th season with it.
  16. winterking
    winterking Captain
    Dec 25, 2011
    615
    211
    NJ
    hey Ripta, would love to hear what kind of numbers you’re getting with the 430 in a bhm?
  17. blinsquirrel
    blinsquirrel Senior Member
    Dec 2, 2011
    183
    162
    Ambrose
    I tried a DQX on my 36 BHM. Had zero gains in speed and efficiency. The wheel was singing at trolling speed. Prop shop said the harmonics were a result of the blades being 99.9% true since they are cut on CNC machine. They recommended taking a file to the trailing edge of the blades.
    I sold the DQX and put my original DQ back on the boat. I think the DQX really shines on hulls that have limited tip clearance....not my BHM.
    ripta13 likes this.
  18. ripta13
    Feb 5, 2012
    215
    224
    1996 31 BHM
    Clean Bottom inshore fishing 2220rpm 16-18kts depending on the tide. Iv scene 19 and 15kts at 15gph. Canyon load with ton and half of ice loaded for 3-4 days is another story. I stick 1450-1500rpm 8.5-9kt 5gph. She’s a pig 4,000 plus lbs heavier. 14kts @15-16gph
    Not to derail the thread but the 2 people I know that tried the DQX and everything I read here were all were pretty positive except $$
    Kailua Kid and winterking like this.
