Garden hose to seawater strainer
Discussion in 'Downeast Engine Room' started by John Hobby, Dec 2, 2019.
  1. John Hobby
    John Hobby Member
    Nov 17, 2019
    25
    6
    Carpneter
    Martha's Vineyard
    2000 Eastern 2710
    Ok guys, here is one for ya. I'm sitting around yesterday and got to thinking how hard it is to run fresh water into my sea strainer and not have it go all over the place with either to much water or not enough or the damn hose flies all over the place. So I was thinking can I modify a lid for the Groco and have a garden hose bib on it. It is a flat top lid. Model 1500. That way when my boat is in the cradle for the fall and spring and I do winterize or other service and need the engine to run I can have the hose connected and run the water and it will be a sealed connection and not making a mess. Is this just early winter mental thinking or is it a good idea. I actually have another lid to my Groco sea water strainer. Just thinking, and not drinking, yet! John
  2. Quik Fix 16
    Quik Fix 16 Senior Member
    Jan 29, 2019
    251
    115
    Fiiberglass guy
    Emerald Isle, N.C.
    Shamrock
    FW flush.jpg Put the "T" into a hose instead of messing up your Groco . I have a cooler rigged with a hose to carry from boat to boat
    CaseyMarie and ThePartsGuy like this.
  3. speedwagon
    speedwagon Senior Member
    Dec 10, 2014
    258
    87
    PJ RI
    This has worked out well for me. Drilled and tapped the lid. The lid isn't thick so a nut on the underside helps distribute forces and keeps everything tight. 1/2 npt with a garden hose quick disconnect. I keep the 10' garden hose connected all the time and regularly use it to fresh water flush. Works great to winterize too. The ball valve stays closed when I'm running the boat so as not to suck air into the strainer.
    BillD likes this.
  4. Genius
    2,880
    1,474
    I put my Tee before the strainer, it makes more sense to me. Also used for winterizing, strainer gets filled with non tox.
    Diesel Jerry likes this.
  5. John Hobby
    John Hobby Member
    Nov 17, 2019
    25
    6
    Carpneter
    Martha's Vineyard
    2000 Eastern 2710
    Both great ideas. Guess I am not that crazy. Boy that strainer is close to those batteries huh Speedwagon, don't need to wash them down. Thanks John
  6. plowin
    plowin Captain
    Dec 14, 2011
    1,317
    943
    Firefighter/Half Assed Fisherman
    Newbury
    33' flowers
    Just take a short washing machine hose with a ball valve on it and attach it to a garden hose. Turn the garden hose on and then when you want water put the short length of hose in the strainer and Open the ball valve. Simple, cheap and no mess.
  7. powderpro
    powderpro Captain
    Dec 3, 2011
    3,122
    2,339
    The Ocean
    O'Neil
    Have you seen these? They are a little spendy , but work well
  8. BKay
    BKay Member
    Feb 24, 2017
    15
    Reedville, VA
    Those are nice and I've used them on a small engine and attached a short section of hose into a bucket to draw NOTOX. But how well do you think that would work on a larger engine - say 220hp or larger - a garden hose is considerably smaller than the 2" raw water hose. Any comments on whether the suction would draw NOTOX fast enough to lubricate the impeller?
    BKay,
  9. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    4,710
    2,528
    Use them all the time for decom season. Or I just pour right into strainer.
    BKay and Genius like this.
  10. powderpro
    powderpro Captain
    Dec 3, 2011
    3,122
    2,339
    The Ocean
    O'Neil
    I’ve used them on 300-500hp Diesel engines with no problem. All you are doing is idling the engine to flush fresh water or run antifreeze through it. It provides Plenty of supply to keep the impeller lubed
  11. John Hobby
    John Hobby Member
    Nov 17, 2019
    25
    6
    Carpneter
    Martha's Vineyard
    2000 Eastern 2710
    All great thoughts and thank you all. Love the already rigged up unit for the Groco. Can't beat that. Thanks guys. Snowing in Mass so a long way from boating. I hate snow!
  12. Toolate
    Toolate Captain
    5,842
    1,773
    Building contractor
    I have found that the thread on my Groco strainers is the same as male adapters in PVC plumbing fittings so this could be made up very cheaply using standard white PVC plumbing parts. Just NPT threads. Easy to put a big O ring on one if you wanted to.
  13. John Hobby
    John Hobby Member
    Nov 17, 2019
    25
    6
    Carpneter
    Martha's Vineyard
    2000 Eastern 2710
    Great suggestion!
  14. djmarchand
    djmarchand Captain
    Jul 24, 2012
    599
    225
    Retired engineer
    Atlas Pompano 23 outboard
    I did the same thing as speedwagon above, but I only use it for fresh water flushing. For winterizing with antifreeze, I first close the thruhull, then I open the lid, start the engine and pour antifreeze into the strainer. The engine sucks it right up.
  15. Diesel Jerry
    Oct 25, 2015
    4,710
    2,528
    I will say having a Y valve after the seacock but before the strainer is the best option of all IMO. The allows for easy flushing of the engine, emergency bilge pumping, and if you have to force feed your engine if the water pump fails.
    Toolate likes this.
  16. Quik Fix 16
    Jan 29, 2019
    251
    115
    Fiiberglass guy
    Emerald Isle, N.C.
    Shamrock
  17. Blitzen
    Blitzen Captain
    3,939
    2,426
    Ex Merchant Mariner
    Anyone interested is going this route make sure that the valve off the "T" has a positive lock closed and cannot be opened by mistake and the end where the hose connects also has a mechanical stop/plug. This arrangement without is a easy way to sink your boat.
  18. RockBottomFish
    RockBottomFish Senior Member
    Nov 5, 2014
    214
    66
    Montauk
    BHM
    This is what i have setup and use as stated by
  19. Diesel Jerry
    Oct 25, 2015
    4,710
    2,528
    Very true. I try to put the Y valve at the strainer to make it more visible and easier to put hands on.
  20. gmac
    gmac Senior Member
    Nov 27, 2011
    436
    281
    gmac,
