Jarvis Newman 12 Skiff outboard options?
eglicomet
Member
Long Island, NY
I got a little 12 Jarvis Newman skiff from the widow of a coworker who suddenly passed away and I'm looking for a little outboard for it. Knowing nothing about them, I'm looking for suggestions.
Thanks in advance.
Yesac13
Senior Member
Thanks in advance.
A 2.5 hp Honda or Suzuki will work fine. A Torqueedo or other brand electric motor will do fine, too. Bigger outboards are a waste of money because the hull likely won't plane. If it planes at all, it'll be awful - bow high up, pushing lots of water... Don't bother overpowering it. It is pretty much a 100% rowboat. Get 7 to 7.5 foot oars and go rowing! If you get skilled at rowing, you will go almost as fast as under power with this boat...
eglicomet
Member
Long Island, NY
Solid advice, thank you.
AP
georgepeter
New Member
Holland 14 Jarvis Newman 12 Duranautic 14
It is a elegant rowboat, mine is from the 80’s and I enjoy it as much as any boat I have ever owned
BKay
Member
Reedville, VA
I've got a very similar boat; although the boys at Newman and Gray say it's not one of theirs. I put the smallest ePropulsion motor on there and it moves hull speed at 50% power. The biggest problem is some of the motors out there have such short arms you have to to sit too far aft to trim properly.
I've only tested the motor once, but it moved at hull speed nicely but I couldn't sit on the rowing seat and reach the motor. Make sure you've got a long enough tiller arm to make the seating position comfortable since those dinghy's don't like weight aft.
fortier256
Narragansett Bay
Fortier 26
Pretty skiff. How big?
eglicomet
Member
Long Island, NY
Well, I ended up with a 5hp Honda for cheap and it works out pretty well as long as I have someone sitting forward. I appreciate everyone's input. I'm pretty new to all of this and I'm grateful to have the forum to ask questions.
Here's a picture of the first little trip with the family.
BKay
Member
Reedville, VA
Nice, congratulations! That's a pretty little boat.
I solved my trim problem by getting a tiller extension for $25. Now I can sit aft if someone else is on board or move forward to a rowing seat if I'm alone and still reach the tiller.
eglicomet
Member
Long Island, NY
Thank you. I did the same thing and it made it a million times more comfortable, too.
Gaffman
New Member
I have a 12' Newman skiff in RI. I am going to put a fresh coat of paint on the hull and advertise it this week. If anyone is interested you can call. 401-258-6055. Thanks.
