raw water strainer reservoir size?
flatcat
Member
20' inboard skiff, GM 350
there is not a square to spare below deck between the rails, it has a 1" inlet scoop which was piped to an unsupported upsidedown strainer about the size of a football,
from there thru the trans cooler and to a crank mounted pump
pump capacity is 5 gpm @ idle and 24 @ 4000 rpm
probably the bigger the reservoir capacity the better, but where is the min? is there a min?
I have seen some spin on style as small as 2 cups
thanks for any knowledge/insight
flatcat
Member
i got that , i just want to downsize the actual reservoir size without any side effects
now i'm thinking about those other style strainers mentioned in the other post and doing away with the in line
thanks
Top
