Richie Compass
Discussion in 'Downeast Boat General Discussion' started by archsea bunker, May 12, 2019.
  1. archsea bunker
    archsea bunker Senior Member
    Mar 25, 2012
    114
    18
    OK so I put the boat back in the water and go for a run and all is good except I notice my compass Richie power damp 5 inch dome flush mounted compass is not working , the compass dial is dipped to one side and only moves slightly seems to have enough fluid inside although I did pick up some, Its a $ 375 item on their site so my learned friends what could be the problem/solution ? Thanks
  2. Brooksie
    Brooksie Captain
    Mar 25, 2013
    1,231
    399
    You may have an air bubble under the card. Remove the compass, tip it 90 degrees, and see if a bubble doesn't come out from under the card.
  3. archsea bunker
    Mar 25, 2012
    114
    18
    Thanks Brooksie I will try that later in the week,soon as weather improves.
  4. xbskt
    xbskt Captain
    1,599
    1,297
    electrician
    28 Crowley Beal
    Ritchie Service FAQs
    You may find an answer in the above FAQ page.
    They are very easy to deal with and are just a phone call away.
    Contact Us
    I just had one rebuilt for Merlin and was surprised at how easy and affordable it was.
    At the very least I got the feeling they would be happy to talk to you if you have a problem.
    Good luck
  5. archsea bunker
    Mar 25, 2012
    114
    18
    Great stuff xbskt, If I cant solve it midweek its going to their service dept, thanks
  6. lobstercraven
    lobstercraven Senior Member
    Dec 4, 2016
    209
    29
    I had a Ritchie compass rebuilt a couple of years ago. It was a discontinued model and they were super easy to deal with. It didn’t take long either. They’re somewheres in Massachusetts I think .
  7. starrfish
    starrfish Senior Member
    233
    85
    nantucket ma
    35 duffy
    i sent my 30 year old compass to ritchie this winter, it worked fint , but cosmetically it was pretty beat, crazing in the dome, coating worn off the flange and green etc...
    when i recieved it back i was pretty amazed at the quality and craftsmanship that went into rebuilding it.. for like 250 bucks
    highly reccomended !
  8. Fouraces59
    Fouraces59 Senior Member
    Jan 7, 2013
    252
    132
    They are in Pembroke, MA about 2 minutes off Exit 12 of Route 3
  9. archsea bunker
    Mar 25, 2012
    114
    18
    Thanks Guys Thats where its going, will report back.
  10. albin35
    albin35 Senior Member
    Nov 29, 2012
    117
    43
    This is a video from some years ago. From How It's Made. Ritchie Compass Pembroke MA
    Yesac13 likes this.
  11. archsea bunker
    Mar 25, 2012
    114
    18
    Interesting, Thanks for posting
  12. RenegadeBI
    RenegadeBI Member
    Apr 13, 2013
    18
    Trim/Cabinets
    Norwalk, CT/ Block I., RI
    Rampage
    They are wonderful to deal with. I had a leak, bought a new seal & fluid. You have to fill it using a syringe. Much to my surprise I was successful - no bubbles, no leaks!
  13. BlueMack
    BlueMack Senior Member
    Oct 14, 2014
    443
    161
    New Hampshire
    Bruno & Stillman 35
