Sneak Peek
Discussion in 'Downeast Boat Pictures' started by Genius, Jun 8, 2017.
  1. Genius
    2,095
    917
    the dor-mor or pyramid anchors are ok, better in mud to soft mud than harder bottom. The manufacturer recommends at least a 3:1 scope which is slightly longer than the 2.5:1 used for mushrooms. They don't tend to wrap up the chain like the mushroom do in the tide or wind shifts.
  2. Genius
    2,095
    917
    Monarch Marine gets video...your inspection did happen! Not the most exciting video to watch, but I will try to get some good stuff as it happens....Great gift and idea from the Admiral!
    Keelboater likes this.
  3. Genius
    2,095
    917
    Really like the forepeak fresh water tank. The fresh water pump has enough flow to supply the pressure washer that is used for mooring balls and pennants. I have it plumbed to use saltwater then switch for a fresh water wash down on the winch. It was hard to estimate the size of the tank because of the odd shape. Think it is close to 120 gallons around 1,000 lbs. It trims the boat to its lines when it full.
    CEShawn and Keelboater like this.
  4. Genius
    2,095
    917
    Some video of a pennant install.
    Please "like" the page on Facebook. Monarch Marine
    xbskt and Old Mud like this.
  5. Genius
    2,095
    917
    ...twins on a DE, or is it? Recently added controls for the winch and gallows at the helm. Piggy backed on the original controls at the stern with a morse control. I am really looking forward to using this, as it allows me to view the plotter and other equipment when setting moorings.
  6. Genius
    2,095
    917
    Finally getting around to strengthening up the wash rails. Placing them every 4 feet. I hope that is enough. Cannibalized the old bulkhead to cut some gussets out of. Hopefully the weather will cooperate and glassing will be on Saturday.
    jdickau484 and CEShawn like this.
  7. Keelboater
    Keelboater Captain
    4,603
    2,516
    Those blades sure took a beating! I've been using the carbide grit or diamond grit blades for cutting fiberglass and am now a big fan of them. They have no teeth, just the grit. I tried one as an experiment because it just didn't look like it would do the job. And it only took that one blade to cut the entire windshield out of the Bruno, and modify all of the window sizes. I'm not sure how they would work on that material, but my guess is better than the blades you used. Home Depot usually has them if you want to try one. LBI sells a different brand which also works well.
    winterking, Genius and CEShawn like this.
  8. Genius
    2,095
    917
    Thanks for the info on the jig saw blades. I will have to try them. The best I've found is the one on the left. Something about how it clears the chips maybe, IDK. For mass destruction, my reciprocating saw with the carbide diablo blades seem to hold up. Only problem with that, it basically cuts straight lines.
  9. CEShawn
    CEShawn Captain
    Sep 21, 2011
    3,024
    943
    RP35
    Were all learning great things on this thread...
    Frank likes this.
  10. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    3,898
    1,917
    Looks good man. Good job!
  11. Frank
    Frank Senior Member
    Oct 7, 2011
    239
    Retired
    Madison, CT
    A lot of great info.
  12. Genius
    2,095
    917
    Weather man was all wrong today. Got more done than I expected, but I coulda got even more done...
  13. Genius
    2,095
    917
    starboard side done.
  14. Old Mud
    Old Mud Captain
    3,750
    2,914
    Retired Fisherman
    I guess you can sit on that wash rail now ok !!. :)
