Sneak Peek
Discussion in 'Downeast Boat Pictures' started by Genius, Jun 8, 2017.
  1. Genius
    2,424
    1,170
    Where do you get pine tar?
    I almost used turpentine, but the Boiled linseed can said to use mineral spirits.
  2. Genius
    2,424
    1,170
    The guy that built the 2" rough sawn wood deck (which sits on a 1.5" nida core deck) when asked....what did you use to caulk the seems? His reply was something that didn't work.;)
    The hold down bolts were not plugged, but filled with caulk. The seems were packed with cotton or oakum that held water and just rotted. The caulk he used was red, had good adhesion, but no flexibility to deal with the wide planked deck. Cracked and let water in.
    When I said it will be a yearly task, I meant the treatment to keep the wood oiled. Not the caulking.
  3. Yesac13
    Yesac13 Senior Member
    Mar 15, 2018
    185
    75
    That's better than I thought. Still, lots of people only redo caulking once or twice a decade. So I'm mystified how even 5200 can still fail. There are boats with teak decks and black 5200 that is still good 2 decades later. Maybe it is the width of the planks that does it (these boats I think of have narrow teak planks).
  4. Genius
    2,424
    1,170
    I think the 5200 failed when the plank had higher moisture content and when I applied the caulk we were in a long stretch of low humidity and hot weather. The planking shrunk and the dry weather did nothing for the 5200 cure. It basically cracked in the center like it was being pulled apart. The caulk stayed bonded to the wood, only stress cracks in the center. If I could have changed the way I did that section....I would have moistened the area during the day to promote the 5200 cure and stabilize the shrinking of the plank.
    On another note the polysulfide Lifecaulk also cures with moisture. It seems this is the preferred product. Reviews and comments say it stays flexible longer than 5200 and has adhesive qualities approaching that of 5200.
  5. steveinak
    steveinak Captain
    4,520
    1,907
    H&H / Pen Bay
    just a offhand thought maybe look up a product made by permachink they make all kinds of caulks for log homes, the logs move/swell quite a bit with weather changes like a wet deck.
  6. Genius
    2,424
    1,170
    I'll have a look! not only for the boat but for the camp too:)
  7. Genius
    2,424
    1,170
    Setting a 400# mooring today
    El Mar likes this.
  8. Quik Fix 16
    Quik Fix 16 Member
    Jan 29, 2019
    66
    23
    Fiiberglass guy
    Emerald Isle, N.C.
    Shamrock
    Pretty much the same as we [us old timers] used on the clam tonging boat decks.
    Genius likes this.
  9. traditions
    traditions Captain
    Oct 9, 2011
    1,160
    318
    38 Holland
    Hamilton Marine
