swivel rings / Green stick main line
Discussion in 'Tuna Talk' started by HUNTHARD, Dec 6, 2019.
  1. HUNTHARD
    HUNTHARD Captain
    Mar 22, 2013
    1,779
    1,290
    Produce Sales.
    Hampton Bays, NY. / RI
    42 WESMAC
    Working on finally getting everything together for our stick this winter. I had friend bring me some swivel rings for the Main line to attach the Long line clips too but they are just too small for the L/L clips we use. Think he got them from sound and sea. Does anyone know the right size and where I can order them. Also does anyone know how wide they are? I want to make sure they will fit through the block I have smoothly.
    Thanks.
  2. sockeye
    sockeye Senior Member
    Nov 18, 2011
    125
    64
    BHM 31
  3. HUNTHARD
    HUNTHARD Captain
    Mar 22, 2013
    1,779
    1,290
    Produce Sales.
    42 WESMAC
    I am pretty sure that's what i have and you can't get a long line clip on there.
  4. Jay c
    Jay c Senior Member
    Dec 4, 2011
    317
    95
    31' Duffy
    Give Sea and Sound tackle down in Wanchese a call. They have every bit of Greenstick gear you could ever want.
  5. jim
    jim Captain
    Jan 4, 2012
    1,058
    1,166
    Retired FDNY, commercial tuna/sword handgear
    Rockaway, NY
    48ft Dixon
    Paul IMO you are better off snapping the drops directly to the main line. Less connections to fail and less weight on the line means less sag. Not to mention less money. Just my two cents that aint even worth that!LOL
    jim,
    HUNTHARD likes this.
  6. tunaorlater
    tunaorlater Captain
    4,261
    2,267
    LIPA lineman
    Agreed. I used Bennett trim tab hydraulic line over the main line. Crimps on each side. Long line clips spin freely.
    HUNTHARD, Estimator and jim like this.
  7. jules
    jules Member
    Dec 7, 2012
    27
    Air Break tubing works well to I think 5/16 for the 800 is good
    jim likes this.
  8. HUNTHARD
    HUNTHARD Captain
    Mar 22, 2013
    1,779
    1,290
    Produce Sales.
    42 WESMAC
    ok thanks guys that's how my last stick was set up. I wasn't sure if the rings were the better way to go. We will just stick with tube on the line and a crip on each side. I never had one slip over a crimp so i guess that's the way to go.
    thank you.
    jim likes this.
  9. Fishinengineer
    Fishinengineer Senior Member
    May 15, 2012
    169
    53
    Retired Merchant Marine Chief Engineer
    Suffolk County, NY
    Duffy
    I use the two swivels with a ring where the break away attaches. I welded up a larger ring that the L/L clips can attach to comfortably that still fits thru the block on the reel. Somehow I wound up using that Bennett tubing also, had some kicking around and the size was perfect for 3 or 3.2 mm mono.
  10. tunaorlater
    tunaorlater Captain
    4,261
    2,267
    LIPA lineman
    Of course you made your own! Once an engineer always an engineer
    Fishinengineer likes this.
  11. jaybyrd83ecu
    jaybyrd83ecu Member
    Sep 11, 2014
    76
    25
    Wanchese
    I use the rings on my bandit and chafe gear version on my 130 crank set up. The trick with the rings is to attach your clip to the ring at a 45* angle to the mainline when the swivels are straight inline. I'm using the big heavy duty LL clips with the swivels on them. Give it a shot if you still have them around and see if it makes a difference. Its better for me than bending the swivels and line around and trying to attach the clips to the ring.
