Yanmar 6lpa dtp 260
Discussion in 'Downeast Engine Room' started by m williams, Jan 16, 2020 at 9:19 AM.
  1. m williams
    m williams Senior Member
    Nov 16, 2011
    255
    55
    Warwick ri
    Bhm 28
    Good morning guys. I am going to be looking at a yanmar 260 hp lpa dtp 2005 year with zf 63a transmission the engine is in Marshfield ma came out of 28 bhm Engine has has 2204 hours on it. What are some things to look for on these engines What is there life expectancy the engine was posted on here back in September
    Timing belt was changed at 1100 hours
    Oil changed every 100hrs. This all info I got write now
  2. Gurryman
    Gurryman Captain
    Sep 6, 2012
    1,145
    670
    New Bedford MA
    Nauset 28, CuttyHunk 28 Molds
    If you have to ask, you should probably bring someone that knows the engine. JMHO
  3. m williams
    Nov 16, 2011
    255
    55
    Warwick ri
    Bhm 28
    Are these engines 24 valve or 12v
    Any real big issues with these engines
  4. Genius
    3,031
    1,577
    timing belt and valve guides are the issues I've heard about. I understand most of the valve guide issues have been corrected, but it may be prudent to confirm.
    As with all engines, the exhaust design is usually what gets them in trouble. Inspect the turbo for replacement (why?) and if rust is present in the exhaust side. Heat exchanger maintenance records or indications of service is a plus also.
    ZF63 is a good reverse gear for that application.
  5. Kailua Kid
    Kailua Kid Senior Member
    Jan 14, 2019
    202
    103
    Maritime Lawyer; Fisherman; USCG Master 50 Ton
    Bainbridge Island
    The 6LP DTP is a 24-valve engine. Should be a 4000 hour plus motor, with proper maintenance and correct prop pitch (to turn up to 3800).
  6. F/V KRISTA MARIE
    F/V KRISTA MARIE Member
    Feb 4, 2015
    82
    16
    Stamford
    General Marine 26
    12 valve
