Downeast Boat Forum banner
What’s the best material for a Dashboard Panel?
10K views 36 replies 24 participants last post by  HankB
#1 ·
WharfRat is setting me up with a new Simrad Chart Plotter.
Since the cutout in my helm is too big I need to make a new Dash Panel.
I'm only doing the left side of the helm for now, someday I'll probably replace the displays and VHF Com on the right side and will have a professional build me a custom Dash panel.
In the meantime it's up to me.
Material options? And thickness?
I'm thinking Black King Starboard (off brand) of either 1/4" or 3/8"
Or Black Plexiglass either 1/4" or 3/8"
Thoughts? The panel will be similar to a picture frame with a 1 1/2" boarder.
Thanks Dave
PS, I found an online store BuyPlastic.com that has good prices on smaller sizes. View attachment 1141795E-68B3-4300-84E3-AB0EEA24DAE1.jpeg
#2 ·
Dave, i was going to say 1/8" Stainless but that would be a lot of work. And seeing as all your gauges / instruments are black i would say stay with the black plexi. At the same time you could purchase the whole panel for the do over and draw it out so you can have it lasered.
#4 ·
Thanks Old Mud, I agree with the plexiglass, is 1/4" ok or go with 3/8"?
I think the chart plotter weighs about 6lbs
When in doubt, use the thicker material. I've never regretted using heavier duty material, but I've regretted many times using material that was too weak or flexed too much. 3/8" is what I would use.
#7 ·
I'd reach for an opaque plastic material, preferably one that's easy to cut.
Starboard, equivalent, or even PVC board (which you can just go buy at home depot BTW).
I might go 1/2 inch, but for sure a minimum of 3/8. You don't want it flapping, you want to be able to put a screw into it and have something for it to hold onto. Edges can be rounded over for cosmetics with a thicker material.
#13 ·
I had a similiar situation years ago. I cut one out of 1/4” plexiglas then spray painted the back of it jet black. Once it was in place and everything set into it I picture framed it in mahogany or teak I cant remember. Worked perfectly and looked outstanding. The paint on the backside prevented the black from being scratched off so it always looked great. Super inexpensive as well which at that point was very important to me.
#15 ·
If you want to send me the unit you are putting in and your outside dimension I could get you a price on matte black or shiny acrylic trim cut to fit. It can be pre drilled for fasteners or left bare so you can do it yourself. It can also be prepped for back fastening so you do not see it. Both gloss and matt are nice, but depends on what you like. You will not get glare on gloss in a wheel house that you will notice. You need large areas in gloss in the sun to notice it. CDevil just posted an all Matte dash and I really like it.
#22 ·
as mentioned above, i did the same with black starboard...however, the best choice i made was to get a sheet of mdf from lowes and make a template out of that..with all the holes etc etc..once i was happy with the trimming and sanding...i used a trim bit on a router to trace it on to the starboard, would imagine that you could do the same with plexi if you go that route. I did have to put a couple holes in it to hold the two together while i did the routing.. I put those through in to the back of the starboard (i went way thick @ 3/4") but not all the way through it so there is no sign of the holes on the front side. came out nice...looks clean...solid as all get out.
#24 ·
I know it's a stretch from doing it yourself but I came across a company that not only does very cool etched rocker switch and stainless waterproof push switched but also custom panel out of a Matt acrylic cut to whatever design you send them it's New Wire Marine in Charleston? they also etched the panel and back light it with the name of your boat, I only bought the switch so far since I m not sure how I will organize the helm panel but they do a great job
Projects
#25 ·
Thinner materials will flex, and can crack over time.
3/8"-1/2" black plexi can be de-glossed with a medium rubbing compound, leaving you with a satin luster.
Glassing the dash in and fairing, then cutting out the new opening will look like a new factory install, though that is a more complex job.
View attachment A8E347F3-F363-442D-8383-463FE690DBC8.jpeg View attachment 10858E68-83B7-41CD-A725-9A24C4C1F055.jpeg
This is made from 3/8" Starboard, back rabbeted, rounded over on the edge, hand scraped and flame burnished.
If you use 1/2", you could flush mount the bezel of the Simrad, and rabbet the perimeter to set into your opening.
Leave about 5/16" on the perimeter and round over for a thin, classy look with a thick, rugged panel for the job.
#29 ·
Black Kydex
Easy to work with. You can form it also. You can glue it easy with THF. TETRAHYDRAFLORINE on a dash like that I have used 2 1/8” pieces laminated with THF the cut to size and drill. Have made recessed switch panels with plug forms very. Ice product.
#31 ·
Black Kydex
Easy to work with. You can form it also. You can glue it easy with THF. TETRAHYDRAFLORINE on a dash like that I have used 2 1/8" pieces laminated with THF the cut to size and drill. Have made recessed switch panels with plug forms very. Ice product.
That's an interesting choice!
How stiff does this material become after laminating?
#30 ·
I was faced with a similar job for our Sabre 38 for the engine display. Our helm is very similar to yours. I made a frame using cherry that fits right in with the rest of the boat. Anything else is going to stick out.
#33 ·
Thanks for your reply, our boat is a 36 Sabre the cabin is finished with mahogany but the helm area is trimmed with oak, so Im thinking of using oak.
Question for your helm how thick is the cherry that you used? And did you glue together a few boards?
I have a planer and was thinking of using 3/4" boards planed to 1/2"
Do you have any pictures?
#36 ·
TCL, my trip to NH to look at the boat got postponed, but I haven't forgotten. I still need too get up to the yard in the next week or so and will get snaps to show the mounting frame.
Hank
