Downeast Boat Forum banner
61 - 80 of 87 Posts
OK still work on the details out with the company, I don’t know what size I need yet I submitted all my specs to them today today. How old are the ones that you have? And are they the same as all the new equipment?
Been working on installing two 450's to the boat. Launched with two 750's, but ended up we needed more coverage.
Built up pads, to level transom, with West System 105 resin and a mixture of 407 and 403 filers.
Didn't use the wood screws supplied, as it's solid glass back there. Decided to drill and tap for 1/4-20 SS machine screws like Bruckmann had done on the 750's. Just need to tidy up and secure cables, then plug in tomorrow.
Hope this is helpful to anyone considering a Zipwake system.
great post, thanks. so after drilled ad tapped, do the machine screws go all the way through the transom ?
Yes they do, about 1/2". It's solid glass in that area and about 3/8" thick. Bedded with 4200 they are superior to the wood screws provided.
The hull is somewhat unusual in that there is an "extension" that supports the swim platform and eliminates the need for brackets. It's separate from the main bilge, has it's own bilge pump, and the stern thruster is installed there.
You're more than welcome. Just be sure to adhere to the torque settings they specify.
3.7 ft/lbs on the outer module with the blade - too tight and the blade will bind up...
Even less on the motor/cable assembly - think it's 1.5 ft/lbs.
May need to borrow a really light torque wrench, I did.
After reading the outstanding write up by Charles @ArchHibb I am installing 750s on our WC34. Due to the curvature of the transom I am bonding 1/2" G10 plates and tapping and using machine screws. My question is the angle of the plates some say should be perpendicular to the centerline and others say it should be an equal gap at both ends.
Who is correct? Has Jamie from Imtra chimed in on this question before? Curious and ready to mix in the cabosil and install them and launch early.
Discussion starter · #71 · (Edited)
@ytmarine - The specific angle of the interceptors relative to the hull centerline does not matter. Instead they need to be the same angle relative to the centerline and the same distance from centerline. The small angle between the blade and the direction of water flow - the blade's angle of attack - is inconsequential to their performance.
The reason for this is because interceptors work by creating a low high pressure area directly in front of the blades. As long as the geometry of that space in front of the blades - which is defined by the trailing edge of the hull - is the same port & starboard, the pressure drops increases will be the same side-to-side, and the trimming effects will be the same = balanced trim.
ArchHibb is correct regarding the transom angle not being an issue. However, I believe it creates high pressure in front of each blade. High pressure is what causes lift at the stern. Low pressure would cause the stern to settle lower in the water which is what you don't want.
The kit with a pair of 750's was $2,700 including shipping. I recently read that Humphree offers interceptors that are even faster and have greater blade depth. The motors are also located inside the hull and can be serviced/replaced without requiring a haul out. All that said, I cannot find pricing for them anywhere and suspect they are more expensive.
Call power products in Wakefield ma. That is a volvo product.
61 - 80 of 87 Posts
